Hi all we masked up the car last night inside the doors and i am buying a liter of paint tonight to do my door jam's. The thing is what ever paint i buy tonight is the paint i am going to use to do the whole car so thats where you guys come in ill tell you what i was thinking and maybe someone can post their opinions thanks please no stupid shit.
I was considering 350z black as its a nice black its Forest Black i think, I considered this because i have seen a few 350z's that looked crazy when washed but now i am starting to think that its to flat and there is nothing special to the paint its just a flat black.
P's: I don't want pearls or custom colors that are going to give me problems later on i just wan a basic color off a black Nissan.
The second choice was the standard metallic black off the R32 GT-R this is nice and has sparkles in it which kinda put me off before seeing little colored sparkles through the paint but at least its got something to it and its not plain and boring so let me know what you guys think and i might be able to make a decision by 3pm unless my head explodes from thinking about it to much .. thanks
what colour is the car now? if its black rubbing down the paint now will be ok to go over it but if you are changing the colour of the car I would suggest priming the whole thing first. Just make sure you know what colour you want and go with that it, its your car so its your choice. Im a person that needs some kind of effect in the paint, it maybe metallic or pearl cuz plain colours dont do it for me sorry. Just take your time in deciding dont rush things it will still be there tomorrow :cool:
what colour is the car now? if its black rubbing down the paint now will be ok to go over it but if you are changing the colour of the car I would suggest priming the whole thing first. Just make sure you know what colour you want and go with that it, its your car so its your choice. Im a person that needs some kind of effect in the paint, it maybe metallic or pearl cuz plain colours dont do it for me sorry. Just take your time in deciding dont rush things it will still be there tomorrow :P
yea the car is in total primer it was already black but im doing the door jams tonight thats the thing.....mmmmmm ff**k so hard to decide i might go the metallic if no one else persuades me.
Any metallic paint will look awesome in the sun. Dont get a plain n boring colour.
In all honesty you should have chose and bought your colour before you started...easier that way
Already got the paint got the code off here its the black pearl metallic opened the can looks sick not much metallic but its there so the paint ain't so boring looks tuff thanks for your help
Good choice! wish I found this thread yesterday..
I agree, plain colours are just too.... well... plain.!
I love the Midnight purple my 33 is, how it changes colour a little but not heaps like some.
If I was getting a re spray it would be a dark metallic black over a dark cherry colour...mmmmm
Put pics up as you go and show us your progress..
good luck!
good luck!
will do man couple weeks and ill post picks up
Thought i would post some pics up of my paint so you can see what it turned out like it has gold sparkle in it? lol i duno why but looks sick i guess with clear on it should be good when its all done.
looks good man just need to use a proper mask even though you might not feel the effects, paint is fairly bad for ya health an investment into a good mask would be a good idea :( Other than that keep up the good work?
Yea mate i know but i didn't spray the whole car i just ran in and did the rear just learning as i go i guess but yea my nose was black after it we were getting high off that crap ! my dad had the mask i got it for him but when we spray in the booth i aint even going in there :banana:
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
