I've noticed that my dash clock runs fast by about a minute a month... it is just really annoying. Seeing that the timing is regulated by quartz, i can't understand why this might happen...
Has anyone noticed this? I discovered it as about 3 months ago i installed a new head unit, and set both the dash and head unit clock to my watch. The h/unit and watch still read the same, but the dash clock is fast. What is the deal? am i just going mad???
:confused:
Originally posted by Shell
haha never paid that close attention to it really...
i never have it on the right time anyway, I put it forward by 5 or 10mins cos I'm always running late :P
right on its the only way to be on time or just a little late to work rather that an hour late every day hahaha i have the same lateness disease
Originally posted by T0nyGTSt
It's Japanese time bro.
E=MC^2
When you run f00l seek times, the real world slows down but time in the Skyline cabin speeds up.
Pay attention in physic class.
T.
ROTFLMAO:bahaha:
Originally posted by Spooks_Skyline
yup, fair call
my clock is always fast, regardless of what time i set it to;
doesnt seem to get past 10 minutes fast though . .. .
Simple solution - set the clock 10 minutes slow. Then eventually it'll be right and you'll never have to touch it again :P
Yup Tony nearly got it right. :uh-huh:
The smart buggers at Nissan had this figured out. The Skyline clocks have a built in auto-relativity compensator. The system calculates how much to slew the clock to compensate for speed/time.
The faster you go, the faster time will pass outside the car. It will seem like a shorter time to you and the povo clocks inside the car.
Your watch and head unit would not have this feature so they will always be slow.
:P
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
