hey guys
i haf this problem whereby my burnt cd's SOMETIME do not work.
often it works when i load another burnt cd that ALWAYS works..and then after it starts loadin and playing, switch it to the one that doesnt.
once that happens, then i can listen..
if i try to change tracks, it takes what...3 -4 mins to load it man!!
ergh....
esp. those specially burnt tracks with romantic songs to lure chiqs...imagine em stalling
sigh
>.:P
any suggestions?
https://www.sau.com.au/forums/topic/23985-burnt-or-not-burnt/
This problem is not uncommon. Many decks struggle to play CD-R's.
Additionally, more often than not it will be a certain type of CD-R that won't play. For example, my Nakamichi CD-700 will not play any of the gold Kodak CD-R's for some reason, even though it plays Verbatim / TDK / Imation and other without problem.
What type of deck do you have?
i have an alpine TDM sumfin deck with a 6cd shuttle that plays original cds like a graceful b*tch but cd-rs, some of the same brand and even not some of the same brand...could it be the
burner or the quality of the cd-r?
It very much depends on the media. Some players still won't play CD-Rs even if they were recorded at the slowest speed. Try a few brands and buy a spindle of discs that you know will work. It does also depend sometimes on the age of the head unit / stacker.
it is because of the reflectivity of a particular media ... most old decks can't play it because the signal coming back from the media is not strong enough ... hence it searches and searches without any luck and goes kuput!!! ... anyways if u dont' wanna change decks then find a better quality media ... especially ones with a coated back if u know what i mean ... or just buy a newer cd deck which amplifies the weak signals so its made for cdr and rw's :P
Buying a new deck is a simple fix, but this may not always be an option depending on budget. I know of a 10 yo alpine player that actually can play mp3's! so its not always the age of the player. Yes your burn speed maybe to fast, yes your format of mp3's maybe a wrong also. I have videos that work perfectly on the computer, then put them in the car and forget about it, dosent even look like playing. More then likley it is the player having probs picking up the signal off the player. go raid ur mates computers for blanck cd's and replace them with your own blank cd's that do not play in your car. this will give you an idea of what works and what dosent. Good Luck
i just burnt a cd last night on the slowest...2x speed or sumfin.
works great nowww...play superbly..able to switch tracks with no probs at all...must be the burner burning at lower quality when burnin fast..
:P
  • 5 years later...
so have we come to a preferred cd brand yet
i'm using Philips cd-R but cant get the stock stagea unit to read them
would it be worth geting gold or blue cdr's to test
also i cant burn any slower the 4x on my version of nero - and its the good nero too
just annoying as i had a fm transmitter fir the old car to play the ipod but even with a converter the jap frequency isn't high enough the read the >106.0 mHz freq from the receiver
i have only 1 station and i hate it !!!
yes ultimate thread revival
but i have learnt starting a new thread is not often wise
Edited by 910trx
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
