hi y'all,
i have four wheels for sale
2x Chrome SSR Professer S1 17x8 +38 (unsure for offset and will confirm tonight) with brand new tyres.. 235/40 (or 45?)
2x Chrome SSR Professer S1 17x8.5 +28 (unsure for offset and will confirm tonight) also with brand new tyres.. 235/40 (or45?)
these wheels came on the car and have gutter rash and other scratches etc.
also have two 4mm spacers that were on the front of my car when it was purchased which the buyer can have
come over for a look or a test fit (i have a jack)
looking for $900 willing to negotiate (tyres alone were $640)
PS - im pretty sure that the fronts (17x8) will not fit on a R32 gts-t m-spec (4pot front calipers) without a spacer (unless you grind down the caliper cover). ZCR test fitted the rears and it looked... awesome!! fills the guards nicely
PPS - the picture below is the wheels on my car with the old tyres still on them
call 0410 149 689
Nerm
Edited by Ex!$t3nZ
https://www.sau.com.au/forums/topic/239949-fs-ssr-professors-s1/
for some reason i cant edit my original post but i thought that i should point out that the stud pattern is 5x114.3 although the more astute readers will notice that i mentioned that ZCR had them on his 32 which as you all should know is 5x114.3 as well. Note sure if you guys knew that the JizZseX100 was 5x114.3 or not
whats the width????
and any pics of them on a 32 or what????
what do you mean by width.. in the original post i said that the fronts were 8 inches wide and the rears were 8.5.. or are you refering to the tyres which are 235/40 (or45) all around
no pics of the 32 unfortunatley..
i gave the number a call but the guy said it was the wrong number haha
oops my number us 0410 146 684.. my bad. i was at the physio anyway so i wouldnt have answered
im not sure if the wheels fit the front with the spacers.. i havent checked
tried calling that one and it says youve got incoming call restrictions activated haha.
wtf.. sim card must have slipped or something?? this phone has been giving me nothing but grief lately, i might need to get a new one..
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
