:P once upon a time there was a.......................................
Squashed bunny on the side of the road .................
So? I have 4 pages of topics I started .... I'm a whore so what? :banana:
https://www.sau.com.au/forums/topic/239966-damo_r34/#findComment-4191493
Im here because it was reported. Should be busy working. :S
http://www.skylinesaustralia.com/forums/se...ult_type=topics
+1 for damo
You usually make a new thread every so often which is a tad pointless. Most really are just wasteland type posts.
But meh.. I careless which is why I have not bothered moving or deleting them.
If you feel the need to tell all via a new thread about your Divorce, An Offer I Couldn't Refuse!, A Slight Change In Plans!, I'm Back! then really thats your prerogative. Personally I just ignore them and and think bah another thread by Ruby. lol. :banana:
But this thread. its closed. Its a waste of space.
https://www.sau.com.au/forums/topic/239966-damo_r34/#findComment-4191508
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
