Item: Mazda RX7 Series 4 1988
Item Condition: Good
Reason for Selling: Overseas commitments
Price and Payment Conditions: $12,950 ono.
Extra Info: Very Clean & Straight 1988 Series 4. Lady Owner since 1999. Rebuilt Dyson Rotary Engine with TO4/66 Turbo. Price Neg.
One of the latest model series 4's. Very tidy car. Has been well cared for by lady owner over the last 9 years and not thrashed like every other modified one out there.
Dyson Rotary 13B Turbo fully rebuilt 2000kms ago. Dowelled, 3mm seals, turbo port. Garrett TO4e/66 turbo P-trim 1.32 rear - only 5000kms old from brand new. 42mm External Wastegate, Aftermarket Exhaust Manifold.
1000cc Indy Blue injectors with custom dual fuel pump setup with external surge tank & malpassi fuel reg. Microtec MTX8. 3" Quietened exhaust. PWR Large Front Mount Tube & Fin Intercooler. Heavy Duty 600HP Clutch with high clamp pressure (very easy to drive). Boost, water temp gauges, turbo timer, short shifter. 16" Advan Light weight allows. 80% Tyres.
Serviced every 2-3000kms with Castrol Forumula R Full synthetic oil, once since rebuild. Has not been boosted. Approx 300 hp at the wheels on 8psi. Genuine reason for sale. Great platform for a serious street / track / project car.
Contact Details: Aku 0411880884 or [email protected]
  • 3 weeks later...
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
