On all our cars we use Quik Trak...
I'm sure u have heard of it b4 its worked when needed...
They almost stole My cuzn's GTR R33 But quik trak cut the fuel off..
I havent heard of the alarm u mentioned but up 2 u
hope i could help
any alarm with 3pt immob and black wires will cut down the chances of you car getting stolen.
you just have to make sure whatever alarm you get it has immobilisers, alot of the pager systems that look trick and have heaps of cool functions don't have immob. and if you are looking at pagers make sure you look at GSM models not FM radio!!!!! (as they have very poor range)
Instead of the wires being different colours (so you can tell what they are for) they are all black. this is meant to make it more time consuming for thieves to work out what each wire does, and hence less likely to steal the car. Insurance companies also request often that an alarm has black wiring to be covered (if you are going comprehensive that is).
There are plenty of discussions on car security on www.skylinesdownunder.com in the Security section. That might be of assistance.
i use qiktrak as my last car got stolen.. also my dad uses it as his last car was stolen (bugger!) ... very happy and the $$ is worth the piece of mind...
$1800 to protect something you apent $20000+ on... i think its worth it... the $1800 incl. 1 year monitoring and monitoring is $400/yr thereafter.
Evan
i have a brant nemesis (6pt immob + keypad) and my mate has quiktrak.
quiktrak is a reasonable hike over the nemesis, but you get what you pay for. i would definitely get QT if you don't have comprehensive insurance.
my car has been in the visitor car parks in apartment blocks when cars have been broken into, and i generally have the most high profile car there and they haven't touched it so i'm pretty happy with it.
i dont have an alarm as yet but i have a kill switch for the fuel pump and other various kill switches.. it would be pretty hard to steal the car i think.. the switches are not visable and some of them aint switches just various wire "plug things" i dont mind spending the extra 1 minute to unplug and switch stuff off knowing that the thief will have a bit of trouble starting the car.
it's kind of like that joke..
two mates are in the bush and they see a grizzly bear coming right for them. one bloke turns to another and says in relief "it's lucky i brought my running shoes!".
his friend replies "what good is that? the bear will outrun you anyway". and the original guy says "that's okay, i only have to outrun you."
the more immobilisers, the more time it requires to steal a car. the more locks on your front door, etc. etc.
i just have to make my car the least appealing in the car park to try and steal, so the better the alarm, the less chance of theft.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
