cmon we need more SAU people. We will have the minimum number, but there are over 300 SA SAU members - surely more people have to be interested in shooting others in the name of sport?
  • Replies 101
*hopes steve is coming* :P
transferring deposit now andrew
Edited by craig R33
Andrew there is a Mallala track day (for bikes) coming up on the same day that I'd like to attend, but the race bike might not be ready.
This means I'm 75% in. If I'm not going to be on track, I'll def be in on the SAU Paintball Battle Royale!
Done paintballing before and its hell fun! :P And I just wanna shoot the .... :O
yeah just transfer me the $10 already .... it is not that hard :P
EVERY SAU event has a thousand people say they are coming, but then on the day every excuse under the sun comes up when they don't turn up. By paying a deposit you are 1. giving me a guarantee that we will have minimum numbers, and 2. that you actually turn up.
i can post in here from the comfort of my home. to deposit money i gota somehow cut time out of my day between work and uni and find a bank, get money out, and deposit it. i barely got time for lunch atm with work busy as. just seems too hard for such a simple thing.
Edited by steveP
+1 to what Heslo said .... even my Mum is tech-savvy enough to use internet banking ....
Don't worry mate, if you are 100% in, and I can take your word on that, then you can pay on the day. But, if you say you are coming, and I rely on that, and then you don't rock up, then we are going to have issues.
You may be a man of your word, but like I already stated, it is VERY frustrating for organisers of events to have a ton of people say on the forums yes, yes, yes, but then when it is time for the actual event have everyone pull out like a little bitch with every excuse under the sun. This event is already a good example - where in Eddy's original post there were well over 20 replies of 'yes I am in'- yet currently I have a whole 4 deposits (excluding my bunch of mates) ....
Cmon we need more people too - it is only $25 ffs - that is a $10 discount off the normal price, and you get to go on a 2 way Skyline cruise half way to Victor Harbor as well! I will be cooking up a barbie for lunch also ....
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
