check the 3 pin connector under the fuel pump access panel - they are a variable earth style level sender.
anything more specific you will need to say what car its for
hay
i have an r33 gtst ill check it tomorrow
thanks
https://www.sau.com.au/forums/topic/242094-fuel-gauge/#findComment-4224326
Does it stay full for ages then drop pretty quickly to empty?
If so, your fuel pump has come off its bracket in the tank.
Its happened twice to my R33.
Hay
yeah it does it will stay there for ages then drope to half way i am parranoid that i willrun out if fuel soi fill it back is it easy to do yourself or get someone to do it
https://www.sau.com.au/forums/topic/242094-fuel-gauge/#findComment-4226766
I fixed mine on the weekend.
Its not that hard, there is a DIY thread on how to replace a fuel pump Here
I suggest:
Do it when you are low on fuel.
Do it in the morning after leaving your car overnight.
Get some rubber grease for the black ring. (its a b$#ch to put back on)
I'll post up the in tank pics i have tonight.
https://www.sau.com.au/forums/topic/242094-fuel-gauge/#findComment-4239386
I suggest:
Thanks for the info mate
https://www.sau.com.au/forums/topic/242094-fuel-gauge/#findComment-4240789
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
