Hey guys, i have R33 gtst 95 model, rb25det engine, anyway car is basicly stock turbo, stock computer, has 3" turbo back exhuast, greddy fmic, avcr b/c, split fire coilpacks, walbro 255L fuel pump installed, now if im travelling along at 60km/h drop it back to 3rd or 2nd and flatten it, goes through the rev range fine until it gets to 5000rpm then it feels like it drops off power until about 6000 rpm then comes on full power again until redline at 7200rpm, now i dont know much about the avcr i have it set up on self learn mode, i have been told that its not the best way to run it, but i just got it set up so it goes to all stars and left it so it was safe, running 10psi which is about right with what a standard car would run with ungraded exhaust on it. still does has this problem at that boost. any ideas??
Cheers
Daz
my car does this aswell
but mine is a r34 gtt auto and doesnt have the mods you do, pretty much stock.
revs up smoothly till it gets to about 5k
although depends what gear its in. 1st and 2nd gear revs all the way smoothly. this happens in 3rd and 4th
also curious to find out what causes this...
plugs are gapped down to 0.8mm, unless they have opened up in the last 3000km since i changed them at my last service, and also
The R+R thing seems to be what its doing, but on the avcr it wont drop boost below 10psi coz that's what it runs standard now with the exhaust and extra flow. i have got it running pretty much the lowest boost it will with the standard wastegate.
Either get a safc II as a cheap fix so you can trick the AFM readings so it won't drop in to R&R, or go the half hog and get a piggy back ECU or go the full hog and get a replacement ECU and get it tuned.
Getting it tuned will change the way you car feels. It's worth the dosh
I have a power fc sitting here ready to go in, but was going to wait till i got bigger turbo and injectors first. so dont wanna get it tuned yet. the thing is it never really did this before i had fmic and avcr and fuel pump installed, so its gotta be one of these things that are causing it to do that.
Yes, well a tune will fix your problem though. Your standard ECU is having trouble trying to manage all these new changes you've added to the car, its freaking out and trying to play it safe at the expense of your fuel and performance.
i have the same problem on my r34 neo gtt b4 but mine is totally stock in the hood but same with you its cutting from 5k -6k then goes smooth from there. my problem was the spacings on my plugs, when me and tony took it out and put new 1's in with the .8 spacings problems went away.
thanx for that. i will be replacing the plugs again soon. so il post in here if its fixes the problem. i actually have coppers in there at the moment and gapped them down to 0.8 , they have only been in for 3000KM but i will put the iridiums back in maybe this weekend, see if its changes it at all. the gaps on the coppers might have opened up in that 3000KM and could be causing the problems.
noob question but how do you "gap" them?
well, when u buy plugs they come with a different gap sizings between where the tip of the plug is where it arks to, you have to get some feeler gauges, which come in different size gaps you put them in between where the tip is and where it arks out on the plug and tap the plug gently against a bench or something so that the gap will decrese in size to the size of the gauge. that makes it easier for the spark to travel across the distance bcoz its not as far for the spark to travel. normal copper plugs u buy are usually about 1.1mm gap, the iridiums are already gapped down to a 0.8mm so you shouldnt need to touch them.
Well you can buy them pre gapped. Iridiums do come as a 1.1mm. So if you want .8's you buy .8's, if you want 1.1's you buy 1.1's.
yeah u are right i think. lol but i really have never bought 1.1 for my car in iridiums, not really worth it in turbo cars.
yeah I bought 1.1's for mine and haven't experienced a problem with them. But for everybody else, may as well just cut the crap and go for .8's. Spark plug gap arguments are another topic by itself so I won't raise it in here :P
Well today i got to and managed to change the plugs back to my iridiums from the coppers i had in there gapped down to 0.8, and now that the iridiums have been sandblasted and cleaned by me at work, there like new again, and work great. rev's all the way through the rev range now without hesitation, cheers guys, i had a feeling it might have somehting to do with the copper plugs. but seriously they were only in for 3000km and the gaps must have increased or something, i thought they woudl have atleast lasted the 5000km but turns out they didnt, but they plugs werent that dirty either.
I had the exact same problem in my 33. The car feels like it bogs down in that rpm range (feels like going through wet sand or something), so i purcahsed power fc, got it tuned and it now runs great, pulls hard all the way to redline!!! Your pretty lucky that it was plugs, it wouldve saved me a lot of money if it was the problem with mine!!
Edited by RB JET
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
