if you guys are interested in getting some photo work done, i would love to come along, only have 2 issues..........
1) i drive a yaris so i don't think you guys want that on the cruise, even tho it is a cool yaris ;)
2) I think i only know one person on here.... Kidafa
would have finished my exams by then and also my 10-20mm lens would have come in by then...
  • Replies 166
Mark as in Mark that I saw at the Vic when I was there with my manual Stagea? If so, it's Peter. I used to work down at Lonsdale not in plumbing, but in irrigation. If it is who I think it is, you will know what I mean by that, hahaha.
Anyway, the more Stageas the better!!!!!!!!!!
yea thats me lol....
might see you all on the cruise. pending if i can get tint, zorst and detail done by then
ill pm you.... i HAVNT heard from the following people...
rsfour
rsfour1
daysrs4
stagstock
mr500
jav360
bensdr30
shadowknyte
32godzilla
snoozer
dazza88
piratewake
kombi86
dmonic
ryhs5164
ill pm them shortly... cheers
Edited by chef_stagea
who wants to wash my stag before the big day??!
looking forward to it, hope there are some good driving legs; want to give the girl a run.
been hitting up the twisties a bit at night, going really nicely. good power and handling ability
So how is the planning of this one going Adam?
Really looking forward to it! :P
yeha good man. spoke to ruby last night and looks like its going to be the biggest 1 yet! :D if any one spots a stag tell them!
incase any one missed the meet point pm me again. but WE ARE NOT meeting at newton like i think some people think we are. if your confused pm me. :D
:P Um.. i dont think we're gonna be able to make the cruise next sunday... the stag is currently sitting on 98,700km and we can't service it until next month so gotta make those km's last! NOO!! Stupid car :D So dissappointed... GODDAMMIT!!!
Sez
Sez
for real? 100k service doesn't have to be done bang on 100thou.. just come.. without excuses :D
;) Um.. i dont think we're gonna be able to make the cruise next sunday... the stag is currently sitting on 98,700km and we can't service it until next month so gotta make those km's last! NOO!! Stupid car :( So dissappointed... GODDAMMIT!!!
Sez
our RS4 got serviced 13000ks after the 100000ks mark and she's fine! :D
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
