bought stuff from www.takakaira.com before, takes a little while to get here but it is coming from japan, not unreasonable though. prices and range of stuff is good!
you do pay a bit for shipping though.. but again that depends on what your buying etc.. you may want to organize others to buy stuff as well in the one order to minimise postage etc..
https://www.sau.com.au/forums/topic/2430-perfectruncomau/#findComment-44035
Guest | hype^ |
i just recently bought a A'PEXi Power Intake from perfect run,
all up it cost me $180 to my door, and it took 6 days from the day of faxing my details for the product to arrive..
from what iv heard this is very cheap for this product..
:uh-huh:
all in all im very happy with perfect run..
also try nengun performance :P
https://www.sau.com.au/forums/topic/2430-perfectruncomau/#findComment-45127
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
    • Wrong side of sydney for me coming from Goulburn, but you should head along, all ages of Skylines will be very welcome
