  • Replies 359
Nathan, dont test the waters lol
Sorry guys wont be there, cricket
awe but i wanna see if u really can run on water, or if u just sink every time hahaha
na i PROMISE i will behave (i have to)
I'll be there, hopefully with new rims too! I assume same meeting spot as your last cruise Kel?
By the way anyone wanna buy my gold Volk GT-U 17x9 rims let me know :P
Matty
yeah hun same one as last time
PM SENT
I can most probably come BUT im working till 5:30 which means id have to meet you guys somewhere which then means i might have to drive...and thats not something im keen to do...(laser on a skyline cruise??? :) )
So if anyone cant make it till a lil bit later let me know and i shall hitch a ride :P wooop
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
