Item:GENUINE WALBRO GSS341 FUEL PUMP
Age: 8 MONTHS
Condition: EXCELLENT
Price: $90 FIRM
To Fit:S13,S14,S15 R32,R33,R34 A31(cefiro)
Contact: 0413 461 644 [email protected]"]
[/email]Comments: GOOD FOR 200-250RWKW
pic: http://www.lightningmotorsports.com/images..._pump_diffl.gif
Pump information, voltage at 13.2v
GSS-341 and GSS-342
PSI......GPH.......LPH.......AMPS
0..........86.........325.......5
20........79.........299.......6.1
50.........65.........246.......8.5
70.........57.........215.......10.2
100.......34.........128.......13.2
120.......12.........45.......15.5
Item: r32 4 door seats front and rear
Age: 19 yrs
Condition: fair (need a clean)
Price: 80-firm
Comments: good seat in ok condition in need of a clean good spare set of seats
http://i287.photobucket.com/albums/ll127/c...88/P9220011.jpg
http://i287.photobucket.com/albums/ll127/c...88/P9220009.jpg
http://i287.photobucket.com/albums/ll127/c...88/P9220010.jpg
Item: 4 stud 2 peice 4x16'' wheels
Age: ?
Condition: ok front have some gutter rash
Price: 200
Comments: good looking drift wheels come with tyres but tyres are dead bold
dont know offset youll have to come and look
http://i287.photobucket.com/albums/ll127/c...88/P9220030.jpg
http://i287.photobucket.com/albums/ll127/c...88/P9220031.jpg
http://i287.photobucket.com/albums/ll127/c...88/P9220032.jpg
http://i287.photobucket.com/albums/ll127/c...88/P9220033.jpg
http://i287.photobucket.com/albums/ll127/c...88/P9220035.jpg
http://i287.photobucket.com/albums/ll127/c...88/P9220034.jpg
located adelaide - clovelly park 5042
0413 461 644
[email protected]
https://www.sau.com.au/forums/topic/243224-wheels-fuel-pump-interior/
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
