Hey there forum me again just popping in to ask a quick question about missfire. Car is running 10 psi and in the upper rpm it misses and then the car leans out afr's go up to 17. With throttle wide open and in the 4000 rpm range afr reads 12:1 but as soon as it hits 5000 there is a miss and an instant lean out. Now the plugs on the car are ngk coppers number 5 heat range and gap dropped to .7. Do you think that this is the culprit as I should be running a colder range plug? What I want to know is if the car leans out because of the miss or does the car miss beacause of the lean out and also the spark plugs seem to be at fault right? Fuel pump fairly new walbro 040 hardwired for full voltage, spark plugs might be a little fouled as i ran the car rich a few times and I mean rich as in black smoke out the exhaust and they are the ngk 5 coppers. So what do you think?
https://www.sau.com.au/forums/topic/243277-burning-question/
If your getting an ignition missfire then your average 02 sensor reading will look as though it going lean as there is excess oxygen in the exhaust system. Your tuner/dyno operator should know whether or not it is running on less than 6 cylinders above 5000 during a dyno ramp and if it is then I would be willing to bet you have a missfire thats showing a lean condition. In which case you looking for a bad coil or plug or connector blah blah blah.
The heat range of the plug at 10psi will not be of concern. My thoughts are that if you cannot support at least 0.9mm gap at 10psi on a std rb25DET then its time for new coils!
It happened at about 5000 rpm in third gear and boost was about 10 give or take a psi and the wideband showed like 17:1 afrs and it happened when we did it again. No dyno was just doin a road run to set in the boost, when it happened. The plugs are gapped down lower than 0.9 that I am sure of. So I guess it time for new colis then and :wub: I had these set all silicon up as well.
Hey Daboss,
I had a similar problem with mine running lean it went to 16 we didnt even go into boost pinging it head off , it turned out to be a dirty afm the wire had some oil on it, cleaned it with brake cleaner waited for it to dry then refitted afr back to normal. cheers
No knocking or anything, just a miss in the upper rpm on wot. Also I noticed that on cruise anything from 3000rpm and above, at partial throttle now as I am cruising, the wideband reads rich meaning my afr's are lower than 10 as it just says rich on the screen of the wideband. Ok here is the deal installed an atmospheric with an antistall kit so the car doesn't stall, the car doesn't stall but now it runs rich at part throttle. Ideal is good varying in between 14.7 and 15 sometimes I see a 17 or 18 but I say thats just the ecu doing its thing to get it to stoich. Now at cruise 2000 rpm and under afr's are great 14.7 to 15. Now I have a stock untuned ecu and a z32 afm that is set up to work through an afc neo that is also untuned. Do you think chipping the ecu will help with the upper rpm rich problem? I cant tune down low because of the stock ecu and it being in closed loop mode.
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
