ok, well it was in the events thread but ill stick it out here for more exposure.
DATE:- CHANGED TO 1st NOVEMBER (SATURDAY)
TIME:- 10am Meet at BP COOMERA for mountain drive
After meeting at BP COOMERA we shall go on a mountain drive through maudsland up behind hinze dam and over springbrook to LITTLE NERANG DAM. There we will stop and have a yarn, show off cars and look at the mountains (awww :()
at around 12:30 or so we will head on down the road a bit further to skirmish and the mayhem can ensue. I have booked the afternoon session which goes from 1PM and lasts 2 hours.
DETAILS AND COST FOR SKIRMISH.
Everyone must be over the age of 15 to partake in the activity. Old clothing that you dont mind dirtying would be a good thing to bring along to change into. The paint is water based and will wash out (however im not guarenteeing this, if it doesnt come out, not my fault :))
COSTS ARE
$22 dollars per person
$17 dollars for paint balls (i cannot remember the number of rounds you get, i believe its 10 balls)
$7 for camoflagued clothing (for those who wanna hide like chickens or those who dont have old clothes that they dont mind gettin dirty)
please keep this thread clean,
I do need a fair idea for numbers, im hoping for around 15 people or so. (the more the merrier tho) hope to see you all there.
https://www.sau.com.au/forums/topic/24356-skirmish/
$17 for 50 rounds that's a frking rip off, i used to play it everyday and don't mind it but fark it shoulkd be more of $17 for 150 or similar as u will go through about 300 rounds in 2 hrs, but what the hell i'll prolly go.
https://www.sau.com.au/forums/topic/24356-skirmish/#findComment-520417
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
