Hey guys,
Doing abit of a clean up to get rid of misc parts around the house.
1) Pair of Bridgestone potenza grid 2 235/40/17. Abit of camber wear on both, apart from that has around 40-50% tread on both. $60
2) Pair of Bridgestone Potenza S03 235/40/18. One tyre is down to the fabric on the inside as shown, however the other has slight neg camber wear. Still has very good tread otherwise, approximately 60-70% tread. $50 the pair
3) Pair of Bridgestone Pontenza RE030 235/45/17. No camber wear, just on the markers, good if you want to drift or hack at these. $30
4) Oil cooler kit to suit SR20. Came off my s15, comes with all lined, fittings, adaptor plate as per photo. $130
5) Vertex Side skirts from Fibre Designs in Adelaide. These were a backup pair and are the same skirts as displayed on SIGNAL15. Thick glass, and very good quality. $150 for the pair, need to be prepped and painted.
6) Blitz BOV... Not sure what model, but came with the car. $120
7) Stock Dual mass flywheel from S15... In good condition and was pulled out at 80,000km off my S15. $50 (Photos on request)
8) S15 Stock struts and springs both front and rear. No leaks, knocks and works perfectly fine. $180 (Photos on request)
9) Buddyclub gearknob... Off my s15, not sure what else it fits? $30
Parts all located in Sydney (Sutherland shire). Can post interstate at buyers expense.
Contact: Jason 0423 324 906 / PM / [email protected]
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
