more like too old and dated for 500hp.
If you want 500hp (now, one assumes thats @ the motor when you make no mention of rear wheels), then the good ole GT30 fits that.
If you mean 500rwhp, then thats GT35
To the engine.
Im getting a whole single turbo with the T04s set up for real cheap and I was wondering what its capabilities
https://www.sau.com.au/forums/topic/244282-t04s/#findComment-4255606
If you mean the old HKS RB26 kit , split pulse single low cast manifold , the turbo should be a "TA"45S so the next size up from T04B/E/S .
A .
I don't have the ta45s I have the so called T4s "T04s" .Just wondering If i should sell it ,basicly new it was just reconditioned and now im thinking its not enough for me so i'm thinking about fitting a gt4088r down there.If it will fit?
https://www.sau.com.au/forums/topic/244282-t04s/#findComment-4257524
For 500hp @ the motor, why on earth are you getting a turbo capable of around the 700hp mark @ the motor?
GT35 like i said will do 500hp. Best to get a turbo suited, rather than something not thats only going to add lag for no extra gain towards your goal
https://www.sau.com.au/forums/topic/244282-t04s/#findComment-4257536
I assume its a HKS T04S. I had some stats on it as I used to have a HKS T04R and done a heap of research.
Its only a 500 or 550hp rated turbo and a GTR I drove with a HKS T04S turbo was massive responsive and still made 300kw atw. One of the best GTR's for power delivery I have driven... :P.
Will try and find the old info I have saved. I assume you have a HKS T04S kit?
Michael
https://www.sau.com.au/forums/topic/244282-t04s/#findComment-4257639
To be sure if you can post pics of your turbo (front/back/side/ID Tag) I should be able to identify it for you - well at least which series anyway .
There is a lot of variation in what gets called "T04S" or "T04R" .
Normally T04"S" means the 3" or ~ 76mm 7/14 blade T04S series compressor and T04S 0.70 A/R comp housing on the front of a garden variety T4 cartridge .
T04R as in what HKS used to sell as a T04R turbo just had the "R" or 84mm 63T BCI-8D compressor wheel fited to a T04S turbocharger . I think HKS may have been cropping the T04 P trim turbine at one stage but thats nothing any reasonable turbo mob couldn't do .
I used to have a couple of pics of the HKS spec TA45S and if I can find them I'll post them .
A .
https://www.sau.com.au/forums/topic/244282-t04s/#findComment-4258394
A .
https://www.sau.com.au/forums/topic/244282-t04s/#findComment-4258439
I can't figure out how to put the pics but if you give me your email I could then.The guy that sold me the turbo just had it rebuild so its like new now and he said it was supposedly upgraded with a bigger wheel....and spooling full boost in the 5k range which i though pretty hight for a bb t04s..I guess i'll sell it and buy a t04r instead.
https://www.sau.com.au/forums/topic/244282-t04s/#findComment-4258812
lol dont get a t04r. old technology
get a t04z!!!! (thats if the t04s isnt good enough)
The one I drove on a GTR was FULL BOOST 4000rpm and Flew like the clappers with massive midrange
first you need to decide what final power figure you want, and what you using it for? Drags, street, circuit etc etc...
Michael
https://www.sau.com.au/forums/topic/244282-t04s/#findComment-4259299
I need a wall to belt my head against.
5000rpm??? for only 500hp? Madness.
Maybe you've missed it the two times before
GT35
Not T04R, not T04S, not even T04Z - GT35!
https://www.sau.com.au/forums/topic/244282-t04s/#findComment-4259795
Ball bearing T04S ? That would have to be either a large frame P trim/60-1 or a T04Z . How many compressor blades ?
A .
It has 8 blades ,I didnt receive it yet ,its on its way and for the gt35r its out of my price range for the T4 version.
I'm looking for 550 to 600 hp at the fly ,going to be street /drag once in a while.Dont mind a turbo that has a little lag like ex:boosting at 4500 to 5000.
https://www.sau.com.au/forums/topic/244282-t04s/#findComment-4260250
For 8 bladed , what I call 8/16 because they have 8 full height a 8 splitter blades , I think you must mean th old T04B series . There were actually a few 6/12 balded wheels in the B series - the largestbeing the T04B H trim .
Pics when it turns up , A .
So is the T04B rated to more power then the T04s?I have pics i just dont know how to post them...
https://www.sau.com.au/forums/topic/244282-t04s/#findComment-4262190
No the other way round I think . All the T04B wheels I've seen are ~ 70mm OD or 2.75" where the T04S ones were ~ 76mm or about 3" .
My lists show T04B 6/12 (39 to 70 trims) and 8/16 bladed (39 to 63 trims) , plus T04S (TB41 ?) as 7/14 bladed (34 to 58 trim) .
A lot of variation here so I need ID tag numbers and some pics of the turbo preferably with the housings off to know for sure .
A .
https://www.sau.com.au/forums/topic/244282-t04s/#findComment-4262657
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
