I like the meshies with the little bit of dish
the new mags are ok, but the colour doesnt suit - powdercoat into white would look ace, or a smokey grey with pearl clearcoat
keep the mags but powdercoat them a different colour
....... never look back I say
Thanks for all the replies.
It's funny, in the flesh the AVS look much better than the Volks. People at work thought the same today also except for the colour. The picture just doesn't do them justice. I've never been a huge fan of white rims, plus I don't want to have to clean them every 5 minutes so I'm going to get the AVS rims powder coated with a dark gunmetal grey tomorrow and see how it looks. It's cheap as so if I don't like it I'll probably just sell them. Anyone with photoshop feel free to have a play with colours!
Thanks,
Matt
sorry mate the first ones for sure,what were they thinking designing the second set,they may have purpose but look like rubbish,definately look like they belong on a sylvia or something that has no taste or design,id change back unless your using your car for drifting etc,i guess thats what the rims are made for
Thanks,
Matt
ive seen quite a few of both the AVS and volks, i much prefer the volks. but its up to u man, if u like the AVS's more then keep them, that's all that should matter.
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
