quick question for anyone one in the know- wanting to know does changing (increasing) the gain/responce setting on my ebc do anything really like better acceleration or faster boosting ..i had it set on zero now its on 7.1 ?? thanks yall
https://www.sau.com.au/forums/topic/245397-gainresponce-ebcs/
It should bring the boost up to peak quicker, but if you overshoot it it will spike. It simply delays opening the 'gate till a later percentage of set peak boost. You should get a little more torque as boost comes on till it peaks. You might want to set it on the dyno to get this spot on.
to give you indication
before with manual boost tee boost was set to 12 psi. would hit 12 then drop all the way down to 10psi and hold at 10psi stable
after electronic boost controller (greddy profec spec b) and Toshi remap (boost limiter deleted) boost controller set to 12.5 psi and literally holding right on 12.5psi
Edited by DrewII
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
