When i give 'er some revs in neutral the engine stutters for a second or two till the revs build up.
I have gone round tightening everything i can think of.
I have found a small (20mm) long open section where the zorst guy hasnt welded the resonator up properly. Also, when i rev i think i can hear a whistling sound from the AFM which is located just after the FMIC and prior to Greddy plenum.
Question is....which one or both?
Any ideas
Thanks
https://www.sau.com.au/forums/topic/245410-exhaust-or-afm/
Well exhaust you should weld up either way.
It does potentially sound AFM related, but the AFM 'should' play up all the time. Not just in neutral with a little free-rev...
It should misbehave off load/underload/intermittent for both etc until it gets worse and worse (thats how mine failed)
Could also be TPS perhaps not working correctly IMO... more likely TPS than AFM
https://www.sau.com.au/forums/topic/245410-exhaust-or-afm/#findComment-4269215
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
