Could anyone who has done the conversion of vg30det onto an rb20det please supply a few hints and tips. I looked on meggala's site but was after some more info please people. Also, will a vl turbo fuel pump be able to keep up with this turbo happily running up to 12psi boost??? I know you need to rotate the housing on the turbo or something and the oil and water lines won't match up.
For those who have done the rb25det turbo on rb20det could you please list the procedures also.
Im having a lot of trouble finding an rb25det turbo at a reasonable price so im thinking of opting to the vg30det even tho it's a bit laggier. All info would be greatly appreciated.
Thanks heaps people, things are starting to look up for my car now i think.
Jayson
https://www.sau.com.au/forums/topic/24555-fitting-vg30det-and-rb25det-turbos/
Well thanks everyone for your help. Im doing the thing and finding out for myself, will post information as soon as it's done and i've finished having fun with it. From what i have learnt so far, (rb25det turbo on rb20det) run the line from the wastegate to where your boost guage plugs in at the back of the manifold to save tapping into your intercooler pipes. To keep your boost guage just put a T- piece in there. You will need the rb25 lower intercooler pipe cuz the rb20 one won't bolt straight up. I think i may need a different thread size for the water piping but i'll get into it when i get up to it and last but not least, rusty bolts are a real bitch, expect to break a few.
Part 2 coming soon.
Jayson
ps. by the way, i went for the 25 turbo as my car is sluggish off the start as it is and putting a vg30det turbo on there would of made it worse.
Straight bolt up for all!!
VG30bb will have no more lag, but, make less power than RB25
VG30 non bb has a bigger exhaust wheel and makes more power than the RB25 but is laggier
Intercooler pipes don't need to be changed as the Tri bolt flange on the comp housing will bolt up to any of the RB turbo outlets.
or you can just t-piece it off where you plug your boost guage in on the back of the manifold. I have tried lining up the flange from the intercooler piping from the turbo, to the connector that the intercooler hose goes to and the rb20 unit's bolts don't line up as the unit is smaller. Will take pics later to show you. Mine is a series 2 r33 turbs.
just drill and tapp the outlet pipe, screw your "nipple" in that for the boost line that goes to the wastegate on rb25 turbs. Thats what i did, works fine. Just remember to drill a hole in the thick side so you actually have something to make a thread in...
yeah i wasn't gonna be running anything silly. Stock boost till i get a boost controller and front mount then nothing too much. Got dramas now, i don't have the pipe that bolts to the turbo. The one which the cooler piping goes onto. The rb20 one is smaller and nobody has one around. Think one might need to be fabricated which means more cash. grrrrrr
Alright, all is sorted!!!! Does ur's run 0.4 bar stock??? Mine does. I got the r33 piping off the guy who i bought the turbo off for free so it's all good. Can't wait to go out tonight in it. Missed my car!!!! hehe The turbo went on with the only problem being the wastegate vacuum line which i simply T-pieced off with another vacuum line just above it on the cooler pipe. Will post pics maybe.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
