Would you remove badges?
45 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hey guys,
I've been really wanting to de-bagde my 34 for a while now. Just wanting to know if anyone has done this, and the best way of doing it?
Also just want to confirm both the nissan and the skyline badges are put on with double sided tape on all 34 gt-t's? No actual lettering has any holes behind them?
What would you do ??? Answer the poll :P
Cheers!!
Edited by DRFT31
https://www.sau.com.au/forums/topic/245613-best-way-to-de-badge-r34/
Dunno about sedans, but coupe the Nissan and skyline badges are taped.
My old R34 had only the Nissan Badge at the back when I bought it, looked ok but always thought something was missing so I bought the nissan badging and looked much better.
But I must say, a debadged sedan looks very clean indeed
search the forum, most guys on here melt the glue by using a heat gun or hairdryer, and some fishing wire to pry the badge off. Then some cut and polish to remove any evidence of the badging
Edited by Yo-Yo
Previous owner didnt fully debadge the car..
But he just removed the 25GT badge on the back and replaced it with a NISMO one.
Looks clean ..
Was thinking of shaving the boot lid and doors, and removing the badges aswell.
Lemme' know how it goes.
MRXTCZ
Hey man, i've just done the same thing with my R34. Yes it is just stuck on. No hidden holes to worry about.
Here's a picture.
and here's more pics to my build thread
http://www.skylinesdownunder.com/forums/sh...ead.php?t=57554
I'm still contemplating removing the Nissan badge but meh, i'll decide that later.
  • 7 months later...
I want to remove my 25gt badge, but I was getting told that 'oh you know the paint will be faded or there will be a imprint' which kind of scared me. But looking at these cars it looks really clean, can you do it without a hair dryer and remove whatever is left with wax and grease remove?
ye mine had a nissan imprint from beneath it, just needed a good clean and it was all good.
use a heat gun, or a hairdryer to heat the spot up.
then get some hot water and pour it on the spot.(if you cant use a hairdryer, make sure you do this instead)
use some fishing line to work the glue.
a bit of bug and tar remover to remove the excess and its done.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
