  • Replies 43
Lol done!
Seriously though...My suggestion for sydney ppl was thornleigh maccas 8:30am. If any sydney ppl coming lol.
Any ideas?
wheres thornleigh :D lmao!
8.30? ge thats early haha . wat bout cc ppl? twin servos at what time???
hahaha what u will still be asleep at that time??? :) cuz i will be lol... errrm id say round lunch time at urs or the twinies or sumtin sounds goood
Sydney ppl meet thornleigh maccas (near exit sign) 11:30am....leave by 12pm.
Cruise up old pacific hwy then f3 up to the twin servos to meet coasties.
According to google maps, we'll all be there at 1pm :blink:
Sound like a plan?
Edited by nIsMo86
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
