Sorry to bring this up again guys, i sure theres a tread about his, but i can't find it unless its about the GTS-t . I know all the turbo version uses Premium Unleaded, but wat about the N/A model? I got the 1993 R33 GTS25 (Non-Turbo!) So wat fuel do u guys use and recommend? Without harming the oxy sensor.
Thanx in advance...
https://www.sau.com.au/forums/topic/24608-unleaded-or-premium-for-na/
Thanks, so i'm assuming that when you guys said premium unleaded you mean ones like BP Ultimate, Shell Optimax, Caltex Vortex etc... Cause BP for instance, aren't there like the BP Ultimate with 98 RON and the Premium Unleaded with i think 95 RON?
Someone clear this up for me please
Thanx again.
ultimate is the stuff man, never heard of premium unleaded from BP, thats just the normal stuff. Ive got a user handbook which says anything over 95 however because they are run on 100 in japan its reccommended to use hihger octane fuel like shell, BP, which are 98 (from memory) caltex (97) and errm the others lol.
nah the handbook i got was an 8 page nuthing really, just had sum general things about the car, nuthin special really. I suggest u go to that website that skyla put on cos they are pretty cheap the workshop manuals, i would get one if i had the money to get it :D everything about the line would be simplified then at least!
Yea i won't spend $250 for the workshop manual but may be $50 just for the owners manual. Is that the one you got nismoman18?
And skyla for this one http://www.jpnz.co.nz/xcart/customer/produ...12&cat=8&page=3 how much is it in aus dollar plus postage and handling, do you know? It would be good if aust has got one here. :D
ight thanx guys...:burnout:
I think the exchange rate at the moment is about $1NZ = 0.87c AU so you would be looking $43.50 AU. Sorry don't have a clue on what postage would cost.
I do have a R33 owners hand book, but it's in Japanese. But it still comes in handy now and then.
Originally posted by nismoman18
ultimate is the stuff man, never heard of premium unleaded from BP, thats just the normal stuff. .
Bp sell their "BP ultimate 98 octane" and a few BP places also sell "premium unleaded" which is 95 octane, instead of ultimate.
My old R33 GTS ran on regular unleaded, which is what was recommended in the Japanese Handbook. The handbook for my GT-V (RB25DE) recommends nothing but "Hi Oku", or premium unleaded.
Incidently, it's commonly believed that the Japanese use 100 octane (RON) fuel over here. So far, I have yet to find a gas station that listed the ratings of the various fuels available, so it's hard to say for sure exactly what octane Japanese pump gas really is!
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
