hey guys i am in the process of buy a r33 gtst and i noticed that it had a plasticy tappy sound just above idle. Above like 2000 rmp its fine and at idle its fine its just in a short area of the rev range. I spoke to the car yards mechanic and he recond that the was another 3 r33's with the same noise. Its hard to discribe the sound as its not one i have heard before. The mechanic reckoned it was a common noise but havent seemed to find a cure for it as yet last thing they where trying was swaping crank angle sensors for some reason god knows how a crank angle sensor would course a plastic tappy sound unless it was hitting the sensor wheel which would stuff it any thoughts anyone. Dosent sound nasty its just there
cheers scottie
https://www.sau.com.au/forums/topic/246552-r33-gtst-timing-belt-area-nose/
I know the sound, I've heard it on a couple r33's that Ive checked out for my mate. It sounds like its coming from the timing belt cover. Either the cover itself or something inside it. Both cars drove perfectly fine but it does put you off buying the car. Sort of sounds like an expensive noise to fix.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
