hi i am going to be installing a pioneer radio this is the manual
http://www.pioneerelectronics.com/PUSA/Una...ANUAL.Protected
and i understand it all except for were to wire the orange/white wire
and also how to wire in the antenna so it can go up and down or is it powered by the antenna jack
need help like asap
thx
https://www.sau.com.au/forums/topic/246584-audio-instal/
need help like asap
thx
hey dude where u located? always willin to help what do u need to know
https://www.sau.com.au/forums/topic/246584-audio-instal/#findComment-4286019
need help like asap
thx
OK. I understand your predicament. Firstly, the connections that need to be made are:
orange/white - connect to any light source in the car that comes on when you turn your headlights on. In my car, I spliced this wire into the wire that illuminates my cigarette lighter. What this does is when you turn your headlights on, the head unit display turns down a little so as it is not as bright when driving at night. Not 100% necessary, but it does the trick.
For your antenna, I assume it is electric, you can utilise the blue/white wire coming out of the head unit. This is the same wire that turns your amplifier on, if you have one, but it can also be used to raise and lower your antenna.
If you do the connections like that, you won't have any problems with anything and it will all work the way that it should. Just be sure to solder and cover all connections that are made.
I hope this helps you out.
Good luck
Tony
https://www.sau.com.au/forums/topic/246584-audio-instal/#findComment-4288435
Solder the cables and also shrink-wrap them (shrink wrap can be found at DSE for about $2 a tube).
I find shrink wrap the best, because it doesn't tighten down hard core onto the solder job, it shrinks until it makes contact with everything, therefore is you have slight spikey bits from an ammeture solder job, the spikes wont break through the insulation and become exposed points.
I find that if you wrap in only electrical tape, there is 90% change of a sharp bit finding it's way though the tape and becoming a contact point, and this is what causes problems later on in the install.
Some headunits also have 2 remote wires, 1 is for the Amplifier, the other for the power antenna, because the power antenna is only used when you switch the radio on, otherwise if you use CD's, it stays down.
B.
https://www.sau.com.au/forums/topic/246584-audio-instal/#findComment-4288550
i ended up conecting the antenna to the ignition switch so when it is at the aac position the antenna goes up.
so when the car is on the antenna will go up
i did try connecting the antenna to the blue and white wire but it didn't work and i couldn't be bothered trouble shooting
and for the orange/white wire i just didn't bother i prefer it on full brightness any way but if i change my mind it easy to fix
thx for the help every body :ninja:
haven't run it with my speakers
i will tell u how it goes
https://www.sau.com.au/forums/topic/246584-audio-instal/#findComment-4290406
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
