and I agree with discussion. that said there are things best left unposted. I get enough questions on these cars as it is and 90% of them are not on this forum.
in regard to your original problem if you have a autowatch 573 tag on your key then the antenna for it is in the wrong spot causing your car to see TWO keys and then the NATS 5 system tossing the main key out for that round.. that is the reason I wanted to see the car. out of curiosity what do you do for a living?
Edited by Chris Rogers
(soapbox)
good stick to doing that :) you can see what I do for a living and I'm fairly sure you do not tell all your tricks to everyone - nor do I.
when you open a post with a name calling( which an apology was issued on ) it doesn't sit well with others. if you had been nice about things in the beginning I probably would have helped you straight away.
(/soapbox)
now that this has been said - back to what we are talking about.
Sounds like I really got to you Chris, you need to loosen up. And you are totally wrong about me not giving my 'trade secrets' away. If I can help someone with an IT problem, as long as its a fairly quick solution like my NATS problem, then I'll tell them. Lets face it, you aren't going to get rich from helping people reposition an antenna, but you're trying thats for sure, especially with the prices you charge just to hook up a gps to the aux input.
Have a look at one of my other posts, I have found a way to get the CVT oil into Australia at a vastly cheaper way than anyone else and I'm offering to help others that want it, not keeping that little 'trade secret' to myself.
And since when did we start wrapping people up in cotton wool? I've heard 5yr olds call someone a name that was far worse than 'Captain Obvious', don't tell me I've scarred Stephen for life after that, haha
Last time I checked, this is a forum and its open for people to give opinions, and thats what I gave Stephen, what you gave me, and this is my final opinion on this subject.
we'll agree to disagree then. I'll leave it at that.
there are people here that have a lot more knowledge than you or I combined on these - they don't post it here.
I run a business as you know and I do not use a aux in for navi other things - yes.
So is this issue now fixed?
Did you get the right answer?
and no, comments or name calling does not scar me...
Yeah Chris decided to front up with the info so all good.
Anyway, I've moved on from you, don't you know humour when you read it? This relationship we had is over, you can stop posting in my topic now :thumbsup:
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
