Im hoping someone can help me here. I live in the US and cant find a GTS25t Badge anywhere. I contacted RHDjapan about it but they need a part number and that seems impossible for me to get considering the Nissan dealers here dont have part numbers for any skylines. Is there a distributor on the board that can help me get a GTS25t Badge and have it shipped to me in the States? Please email me at [email protected]
https://www.sau.com.au/forums/topic/247358-wtb-r33-gts25t-badge/
Is there a difference between Sedan and Coupe badges? I thought Nissan had the badges almost as an option back in the day for each model.
Edited by KB240RB
