Selling my car as i have a company car and a baby on the way so its has to go. It has only been driven on weekends for the past 6 months
Tyres are about 80% front and rear. Car has been modified tastefully keeping it stock looking to avoid any problems.
1993 Turbo, Manual
First owner since imported in 2006 with 53000kms on the clock. Rego runs out March 2009. Also i think there is approx 2 more years warranty left from the dealer which i have never had to use.
Serviced every 10,000kms with full synthetic oils and new oil filter. Some minor scuffs here and there but overall in excellent condition mechanically and body wise
List of Mods
R34 GTT Wheels
Nismo oil cap
Nismo radiator cap
Nismo carbon fibre pillar garnishes
Nismo leather gearknob and handbrake boot
Nismo radius rods
Nismo Front bar
Nismo Smoked lens indicators
Nismo fuel pressure regulator
Nismo Short Shifter
Slotted rotors front and rear with 600deg Brake pads (about 80% left im guessing)
HSK Fuel cut defender
Whiteline swaybars front and rear
Whiteline pineapples set for all round performance
HKS black face boost gauge in custom pod, very factory looking
300KM/H Speedo
Genuine Skyline floormats
Heavy duty clutch (could be twin plate) has some vibrations
Platinum spark plugs changed 15000kms ago
600x300x75mm Front mount intercooler
Brake master cylinder stopper
Braided brake lines
Hks Style BOV
Kakimoto 3.5" complete exhaust system from turbo back
Quality alarm system with extra keypad to enter code before car starts
Series II rear spoiler
Apexi Air filter in custom fibreglass airbox to keep it legal
Manual boost controller
Fusion 4 ch Amp powering 2 x 6" soundstream fronts and 6" fusion rears
JVC MP3 Player Head Unit
Car has run a 13.5 sec 1/4 mile and Dyno'd at 200RWKW. I have all receipts for any work done to the car and certificates to prove times/dyno
12,000 ono
Located in South West Sydney
I dont think you will find something like this for the price. Thanks for looking
Con
PM me for phone number
Cheers
Edited by tek_01
https://www.sau.com.au/forums/topic/247868-r33-gts-t-manual-black/
Bump, Car still for sale
10K fellas pretty cheap
May also consider trades as i need to buy my mrs a car
Must be Auto, 4 cyl preferably but 6's considered
Must have A/C
let me know what you got
cheers
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
