Anyone using one of these ?? Any experiences ?? Comments thoughts ?
Specs:
Garrett GT3040 Ball Bearing Turbo:-
Aftermarket Applications
Part Number #GSB8005A for 500hp
#GSB8006 for 600hp
Rated 500-600hp
Spec's:-
0.63 0r 0.82 /r Turbine Housing (4 bolt outlet)
0.70a/r Compressor Housing
Watercooler Centre
56 Trim Compressor Wheel (T04S)
55 lbs/min Comp Flow Max.
84 Trim Turbine Wheel
External Wastegate
$2500 new from GCG - Save $460 as it is on special now.
Seems like a good buy. But how good is the turbosharger ??
Considering the XTRGTST-STG2 500hp rated is $2450.00 - and that is on an exchange basis.
I understand that a bit of fabrication might be neccessary to fit the GT3040 to an R33 GTS-T ??
Thanks in advance.
https://www.sau.com.au/forums/topic/24896-gt3040/
Tony,
I think Andrew has the HKS 3040 - this one is a Garret GT3040 - buggered if I know what the difference is.
CGC say that these are either 500-600HP Turbo - but I think Merli's had more potential than that.
If they are similar, then I think may this one would be too laggy for an RB25 - But perfect for the RB30.
Needjapcar - looks sweet mate - yeah keep us informed !@
https://www.sau.com.au/forums/topic/24896-gt3040/#findComment-528984
Originally posted by T0nyGTSt
If you have the AR's you might be able to match it to the HKS 3040 AR's.
It'll give you an idea of spoolability.
T.
You cannot match the HSK ARs, as HKS has proprietry on them.
I am pretty sure Ben Ellis is using a Gt3040 on his GTT in HPI mag but with a 1.** turbine AR, also I think GTSt VSPEC just fitted one.
The hks 3040 uses 50 trim comp wheel, the 56 wheel is used on the 3037 by HKS? the turbine trim is the same.
HKS sell the 0.87 A/R turbine housing with the 3037 as a kit for the RB25, I currently have the 0.61 and although it makes good power at 1-1.2bar, I am sure it is going to choke the engine a bit up top once I start winding in boost, also it is only making 256 at 1bar, so probably a bit more with a larger AR on the turbine, which I intend doing soon:)
I think your choice boils down to where you want the boost and how much power you. The bigger the AR ratio the better the top end, more ign, more power for the same boost pressure - due to the reduced back pressure (the curse of turbo powered engine) but also more lag, although this can be offsett by the use of adj cam gears or cams.
Also if you intend doing cams you will get increased overlap, so a smaller AR could really cause troubles.
https://www.sau.com.au/forums/topic/24896-gt3040/#findComment-529052
Hi guys, that's the one, a Garrett based XTR GT3040, it's going on our RB31DET. If you are thinking of puting it on an RB25, you need to make sure you have the support systems to handle it. Camshafts (256's at least) are a prequisite, as are larger injectors, exhaust manifold, good wastegate, exhaust, intercooler etc etc. All that will make the cost of the turbo seem like a bargain.
PS; for the guys thinking about aftermarket plenums, Ben's car made the 290 rwkw and the 11.9 (I only saw the 12.4) with a standard RB25DET plenum.
https://www.sau.com.au/forums/topic/24896-gt3040/#findComment-529307
man i gotta subscribe to hpi, hate hearing about this in it i haven't seen!!!
anyway, i was thinking of this turbo too! didn't see the special on it though!!! this special takes almost $400 bucks off, should bring the turbo setup down to just over $4K!!
wish i had the money :D plus the $3K+ for support systems!!!
plus upgraded pistons for over 250 rwkw?????
expensive to be sure!!
any ideas on the power difference between using this turbo on RB25, and the RB30/25 setup? sydneykid?
https://www.sau.com.au/forums/topic/24896-gt3040/#findComment-530253
I'll have all the supports - including new (forged) internals, cams, etc - But still running the GCG Hi Flow turbo (500HP).
Thinking of upgrading to another turbo that flows better - But not sure if I can justify the cost right now - Maybe later.....
This GT3040 seems like good value.. I'll give GCG a call !
https://www.sau.com.au/forums/topic/24896-gt3040/#findComment-530454
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
