I have a very near brand new forged motor for sale and turbo kit. If you are looking for a new motor without wanting to wait this motor is for you at a fraction of a price of doing it yourself.
Here are the following details:
N1 24U Iron block (R34) - done 1500klms heat cycled, major prep work done for 1000hp+
Trust/Greddy 2.7ltr full kit: forged pistons, forged conrods, full billet counterweight crankshaft
Carr Conrod bolts
ACL race bearings
Tomei gasket kit
Tomei Restrictor Plug
Greddy Oil pump
Trust sump extension
N1 water pump
Custom head work by Bullet Heads 1300Hp+ same pattern as Willal Racing GTR
HKS 280’ in/ex camshafts
HKS valve springs
HKS cam gears
HKS timing belt
ARP Head studs - with block if sold with motor
ARP Main Studs - with block if sold with motor
Bronze valve guides
Tomei Valves
Stainless buckets
Stainless retainers
HKS GT3037s 56t twin turbo kit - $8000
Short Motor - $14,000
Long Motor - $22,000
Genuine reason for sale, a full drag cement motor has been ordered, this Trust 2.7ltr is good for street and drags up to 9 sec bracket.
NO LOW BALL OFFERS!
Pics on request. Motor on low boost 1.6bar with very minimal timing, undialled cams, and 11.0 AFR's did over 600hp at the wheels on PUMP fuel.
Further tuning would see in excess of 700hp easily at the wheels at 1.8bar. Race fuel tune @ 2 bar would be estimated at 850hp+ at the wheels.
Very strong motor, like new, i have in theory bedded it in and run a low boost tune in it to get it used to boost. These figures were obtained with a HKS
GT3037s twin kit.
I cant see the value in leaving this motor in the garage not being used, rather obtain as much money back as possible from the build.
pm me if genuinely interested.
https://www.sau.com.au/forums/topic/249028-full-forged-motor-dragstreet-set-up/
  • Replies 45
very weird... clearly you have stated the price you believe is fair and for a built monster motor like that you are correct.. guess velocity will have to get more then the change in his ashtray to get some decent parts.
GL with it!
garage saurus in Japan use the same stroker kit for 1050hp at the wheels in the orange R32 GTR, keir Wilson uses the same head on his RB31 R32 GTR which is within 1000hp territory aswell... Both head and bottom end are in the 1000hp at the treads territory.
Update:
Motor will be removed in 2 weeks so any possible buyers wanting to inspect should make arrangements etc.
Willing to trade stock motor and cash to make full payment.
Edited by OS30GK
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
