Steering Boss Kit To Suit R33 Gtst And Sparco Wheel
I have one, but it has a snapped thread in one of the holes that I couldn't be arsed to drill out... I have also lost the bolts :blush:
Provided of course that the sparco wheels don't use anything special.
Hi Adrian, we have Works Bell and HKB Boss Kits in stock if you still need one.
Have a look at our website for further details and let me know if I can be of any further assistance.
http://justjap.com/store/home.php?cat=337
Cheers,
Steve
Hi Steve,
What are the HKB units like for quality/safety etc? I know they're probably not a patch on the Works Bell stuff for quality but how close do they come?
Thanks,
Adrian
I'm supremely confident with a Werks Bell one but now the quick release is looking a little bit sexy. Have posted in The Tuners Group thread about them asking what stock and price is like.
Ouchy. I misread the saving off the RRP of the quick release as the price. So it's not 173 dollars but 600 less 173 dollars.
Never mind. It doesn't cost to dream does it?
I'll take 1 x Werks Bell boss kit to suit ECR33 (HICAS-equipped-but-not-working / non airbag) from the best priced SAU trader that can sell one to me.
PM's welcome.
See that one hole at 12 oclock thats not black? it's got a snapped bolt in it... drill that out and it's all good
also, find the right size bolts for it :P
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
