ITEM : 18X9 & 18X11.5 DEEP dish chrome rims,
CONDITION : Great, couple little scrapes, tyres are about 60% tread.
EXTRA INFO : Made by SAWA design who make and design Rays rims, These have 14cm dish on rear , 7cm dish front. Offset is +6 rear +14 front ( freat to fill them guards ! ) Have also have the couple scrapes on the front face of the rims repaired :-)
PRICE : $2200 - ONO
PICS : YES BELOW
Edited by stylz7
https://www.sau.com.au/forums/topic/249656-18-deep-dished-rims/
Hey mate
Not sure if they will fit 32 GTR or not? I have seen 32 gtr's with wheels like mine with same offset but not sure if they were same width? i was allways told that with a GTR you should have same size rims front and rear but yeah?
Cheers
what car did you have these on? thinking about getting them for my r32gts-t with stock guards - will they fit or wil they stick out heaps? i'm assuming stick out, but by how much?
and are they heavy? two, three piece?
Hey mate
I had these on both my wide bodied 33 gtst and my wide bodied fc rx7, With out a wide body the rims stuck out about 4-5cm past the standard guards.
They are 2 peice rims and weigh about 8kg - 10kg or so each with the tyres
Cheers
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
