I was just wandering how many Km's does a RB25DET from a S1 R33(Life span), usually last?....daily drive, regular oil change every 5000kms, minor mods, and pull about 700km's per week.....at the moment my car has pulled 190,000km's and still going....quite reliable
If it does start wearing out, would the turbo be the first to give way?
https://www.sau.com.au/forums/topic/249866-rb25det-life-span/
My R33 S2 is over 12years old. Sure i had an engine transplant cause the old one has a crack on the cylinder head but i'm still using the original turbo boosted to 0.6bar at the moment. Same as you change oil at 5000km. Seldom revved over 3000rpm before changing gears unless overtaking or final gear high speed runs on the highway. The RB25DET is a strong engine and under normal driving conditions, it should last you for a very long time. My dad's A15 Engine has been through 2 overhauls with the odometer going past 999999 miles (yes miles not km) TWICE and it still starts and runs like new. My dad never runs the car more than 120km. lol
Most important is never skip out on the maintenance. If something is wrong, fix it or replace it.
Edited by teng
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
