ITEM apexi safc, with loom.
PRICE 150 bucks
CONDITION almost new
ITEM defi boost gauge with loom and a defi control box,to suit every defi gauge,water,ext temp,oil temp,fuel press,ect ect
PRICE 150 bucks
CONDITION all good..
ITEM180sx strut braces,to suit sr20,front and rear
PRICE180 bucks for both, very cheap
CONDITIONfine
ITEM 4 stud 17" dish wheels,unsure of brand, front ofset of +26,rears +16, size= 7s and 8s,full set.
PRICE500 bucks
CONDITIONone of the front wheels will need to be fixed ad it has a small dent.
ITEMvertec vrs manaray sports,5 stud, 18" by 8.5 wih ofset +45 ,only 2 wheels.
PRICE350 bucks
CONDITIONalmost brand new, not a scrach on it.. and not a spec of dirt inside or out...
ITEM18"by 8.5 stich wheels, 4/5 stud, ofset +45, pair only
PRICE300 bucks
CONDITIONfew little nicks and scraches, nuthing to bad.
LOCATION every thing can be picked up in victor harbor(SA) or i can send it where eva ya want.
CONTACT ME 0402 675 675. when eva now, of work for christmas
WILL PUT PICS OP SOON,DOESNT SEEM TO BE WORKIN TODAY
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
