NA S15s are quite common and they're easy enough to find.
As for S14s, I personally have never actually seen or heard of one. That being said, I am sure they do exist as I've seen S13 Silvias with NA S14 SR20DE engines in them. S14 SR20DEs have VVT (variable valve timing) as opposed to S13 SR20s. They also slope down at the back of the rocker cover.
So yes they do exist. Finding them is another matter though!
Shane beat me to mentioning the Autech S15.. I read about it in a magazine some months ago (I think it was the HPI Magazine?) and the power result worked out to be around the same as the turbo model with the smooth power delivery of the N/A motor. Problem is that there's clearly more gains to be had in modifying a Turbocharged 200SX, particularly when the Autech is already modified to get that sort of power from the N/A motor.
I think the Autech was also lighter?
Put the money into a compound interest bearing bank account and wait until you can drive a FI car.
Paying 23K in this economic environment for a non turbo S15 is ridiculous.
Mind you, there was a post on here about a sales ad re a R32 GTS-T going for 36K - ROFLMAO
I have seen NA S14's for sale before.
Have a look on care sales
thats because ppl have done the NA conversion in them.
there are NA S14's straight from Nissan factory over in the states, NZ, UK & in japan but Australia doesn't allow them to be brought over to be complied & rego'd - track use is ok
Autech S15 is good and thats the model you want, its around $20k for one.
example of S14 NA (they're dirt cheap too in NZ)
995 Nissan Silvia Pre-facelift 122,000k's
Strong SR20DE engine with a full SR20DET manual conversion(incl flywheel/clutch/Gearbox etc.)
Brand New WOF as of today!
Has a pod filter and exhaust, perfect donor car for a turbo conversion.
Has a Sunroof and also has Air Bags!!!
Rolling on Stock suspension/wheels(15's with near new tread)
SR20DET Radiator
Have coilovers, wide wheels, 5 stud conversion, +t conversion etc etc which could be included for extra $$$$ Contact me via here, P.M. or cell if Interested...
when looking at buying a car, i came across a white s1 s14 that was claimed to be non turbo, couldnt really drive it though at the time no experience in a manual at the time since i was 16 and wasnt really update with specs. but it was located in melbourne.
S14s came in a "Q's" configuration (i.e. NA), but they're not eligible for import.
S15s came in at least 3 NA variants (the regular coupe, which you can't import), and the grey imported Varietta convertible and the Autech coupe with the tuned 147kW engine.
Whether it's a rip off or not is arguable. Unless state governments remove the P plater restrictions in the near future, the price of these cars will stay high as they're the only ones P platers can drive. Low supply and demand driven by restriction will see to that. NA S13s have actually held value, if not appreciated a little, since the P plate restrictions came into effect.
If I remember correctly the Autech is a little heavier than the turbo S15, as the chassis has been reinforced. With a pod filter the thing has an induction growl reminiscent of a Honda on VTEC.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
