I know its lazy but took ages to set this one up!
All the info at the following link =
https://www.tradingpost.com.au/is-bin/INTER....sAAAEePpcxuIDB
Thanks guys
Edited by dare ya
https://www.sau.com.au/forums/topic/250836-r33-series-2-gts-t-adelaide/
all info updated! A bit of interest but yet no sale...
Regrettable Sale, due to house deposit...
First to see will buy!
Silver, manual
97 series 2 R33 GTS-T
RB25DET
100,000k service just done 12 Dec08 with Gates belts and genuine nissan water pump.
208.3kw atw .... on stock boost, getting dyno read out ASAP
Pager alarm with turbo timer built in
Heavy duty clutch
HKS 2540 turbo
Front mount cooler legal
Jazman split stainless dump pipe into spilt 3inch exhaust Apexi D1 legal
Remapped ECU
Apexi power intake legal
Bosch 040 fuel pump
LED tail lights and rare clear garnish
Lowered king springs legal height
New rack ends and bushes. Also camber kit but not installed $220rrp
SSR professors 18inch 3 piece genuine legal size
245 fronts and Bridgestone S03 265 rear tyres were $680 each for the rears! 3 months old
Spare tyres also inc.
400r bodykit
Pioneer head unit and speakers
Standard interior with no marks what so ever
Power windows and mirrors
Driver and passenger airbags
Climate control (icy cold)
Razo gear knob
Boost gauge in dash legal
Lots Spent!
$17,000 NEG
Edited by dare ya
  • 3 weeks later...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
