Cant wait to get a 370z!
in a few years 2nd hand that is.....
All the reviews seem to be very positive.
IMO it looks nicer than the g37, whereas I prefer the look of the g35 over the 350z.
The performance gap between the two cars seems to have widened as well...
Good the hear they fixed a lot of the main criticisms of the old z...being the extremely harsh ride, cheap interior, weird looking rear etc.
Also whilst the old rx8 v 350z debate was a close one, new rx8 v 370z, is a no brainer, definately goes to the Z....seems like Nissan is focusing on their sports car herritage and mazda and their cute little mazda 3...
so what are everyone's opinions?
Edited by danny_tq
https://www.sau.com.au/forums/topic/251557-370z/
Probably not, but a four door for seat car with a reasonable boot is more practical than a 2 seater with a giant metal girder bifurcating the rear storage even if the engine goes through petrol and oil like its going out of fashion.
Edited by scathing
https://www.sau.com.au/forums/topic/251557-370z/#findComment-4354478
The RX8 vs 350Z debate was close?
The 350Z was quicker everywhere than the RX8 aside from constant switchbacks. The only place the RX8 is noticably better is in "feel" and practicality.
I wasn't talking about speed, but all round performance, practicality, looks etc
https://www.sau.com.au/forums/topic/251557-370z/#findComment-4354537
i dont like the look of the new v36
Really, I reckon that all the pictures and the one real version I have seen makes them look quite desirable. Is there anything that you don't like in particular?
Different to a V35 and both of them have there own attractiveness...
https://www.sau.com.au/forums/topic/251557-370z/#findComment-4357032
i dont know....
it just doesnt look anywhere near as agressive or appealing to me as the v35
it seems more like a 2 door family car..
I agree
i think with the 350z and v35, its was difficult to differntiate the two since they had nearly identical performance, but g35 had the extra 2 seats and comfort.
with the 370z and v37, they have tried to differentiate the two, by pushing the 370z more towards the sports car/performance side of things and the v37 towards the luxury side of things...
these minor chnages have actually resulted in the differences between the v37/370z increasing comapred to the v35/350z
https://www.sau.com.au/forums/topic/251557-370z/#findComment-4357783
ooh yeah bring on the 370z, more parts for my car at the end of the day :D
I never warmed to the look of the v35
The new Z looks a bit funny but in a good way, it's interesting to look at, plus it will share the same push button start as the v37, and hopefully it will come with the same touchscreen satnav setup because it means I might be able to get mine working properly. the v37 has AV input cables so you can watch videos through the AUX. I just have to find out how to stop it cutting out when you put the car in gear :laugh:
If the oz delivered 370z models have the hard drive aswell that will be good too, The previous owner in Japan recorded some music in the hard drive, some of the songs aren't bad either, wish I could understand it
Edited by Yo-Yo
https://www.sau.com.au/forums/topic/251557-370z/#findComment-4359557
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
