hey all im a little bit confused at the moment between electronic boost controllers. i currently have a s1 r33 with a Greddy profec 2 spec B. i am running a pfc ecu without the commander.(is it wasnt there when i bought the car), I am looking between the apexi AVC-R and the Apexi Power Fc boost control kit.. Which is the better of the two and do u need the commander for the PFC boost controller..? any help would be greatly apriecated as i have no idea.. thanks
https://www.sau.com.au/forums/topic/251666-ebcs/
i'm running a blitz DSBC spec s which is basically the same....
i'd stick with what you have and spend the money on a go fast mod :down:
fyi my ebc gets me 20 psi by a titch over 3500 and holds till redline...
https://www.sau.com.au/forums/topic/251666-ebcs/#findComment-4356236
Is your boost controller working.. ie holding the set boost without deviating too much? If the answer is yes, then why change.. If the answer is no, have you followed the instructions to see if it is just a set up issue? The only other reason I can see to change (if the ebc is actually working) is that you have excess money, I take donations.. :down:
https://www.sau.com.au/forums/topic/251666-ebcs/#findComment-4356303
I use something a hell of a lot older than what you have.. blitz twin-sbc. not fancy screen, not even a digital readout, just a couple of knobs and a couple of buttons. Holds boost dead flat so who cares what it looks like, or what other fancy features it has. Hidden away in the glovebox as well, better out of sight than ripped off I reckon. Once you have it set you won't want to play with it again. Just read that manual hamish posted up and it looks dead easy.
https://www.sau.com.au/forums/topic/251666-ebcs/#findComment-4356557
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
