failed window guides?-bad scratches
Howdy,
My drivers side window has some bad sratches in two places that seem to me to coincide with it scraping when going up and down. My passenger side window has started this too.
Could this be the guides worn or something? They are electric of course.
I want to get my car tinted, but I should get this fixed before I get it done.
Does anyone know how to fix this!?!?
Thanks for any help in advance...
https://www.sau.com.au/forums/topic/25185-failed-window-guides-bad-scratches/
Mines the same.. its got 2 scratches on the drivers-side window... gives me the sh!ts!!!
Anyway you can stop it from happening??
its pretty common.. cos ive seen a few skylines with the same sh!tty scratches..
you can get them p;olished out, dunno how much it costs, but as for fixing it dont try it yourself, i tried and tightened the window runners too tight when i put it back, im sure they are now clean but whenh iu over tightened i scratched my tint a bit on the inside and now have to get the window re-tinted, so we'll see if that gets scratched when im done getting it replaced :P
Sounds like the scratches are on the outside, basically your options are...
If they are not deep Windscreen O'brien or someone similar maybe able to buff them out and fix it
Or just get new windows if they cant
Basically your seals would have a gap somewhere and when crap gets down there and rubs against the windows it causes this light scratching. I have the same but havnt bothered to fix it, however I did enquire how and my options I received are what I listed above
Good Luck
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
