Hey guys i have a r34 25gt and about 1 week ago while driving my engine light came on, so i pulled over and turned off the engine and turned it back on again, it was gone for about 15mins and it came on again, i took the car to this crappy mechanic and they didn't have the computer to analyze the error code. But they told me to reset my computer by taking the battery and if the engine light dosnt come on again everything should be fine, so i did what he said and surely the engine didn't come back on.
But today while driving to work the engine light came back on, but after work i took it for a drive and it didn't come back one....anyone have any ideas what problem this could be?
I called my local nissan dealer and they said their computer is not compatible with imported skylines...is there any mechanic around Sydney that has a computer that can analyze the error codes?
also a quick question i have a semi auto r34 and theres a button with A/T SNOW what is that for?.
cheers
Edited by MaShi
https://www.sau.com.au/forums/topic/251878-engine-light-randomly-turning-on/
sorting this out is just so simple if you put a teenie bit of effort in - you absolutely don't need Nissan dealer or anyone
you can get the error code in about 2 mins all you need is a piece of wire - I am not going to explain everything as the topic has been covered many times on here (SAU) - what I will recommend is YOU download the R34 Engine Manual - FREE ON NUMEROUS WEBSITES - just google it - then spend all of about 5 mins reading it - it tells you everything you need to know and do
you will probably then work out you have a Code 21 and take all of our words for it that means new coils (Splitfires best) - we all have been thru what you are now experiencing - FIRST just the checklite restart and all appears OK but soon enough if you do nothing one day the car will begin very serious misfiring maybe even to point of not driveable - not good if you are 100s k s from home
believe me you don't need Nisssan dealer or mechanic to fix the problem - so save big money avoiding labour service charges and get to it
Cheers
i wen to get it tested today, came out with error code 21 : main ignition system (something like that), the mechanic reset the computer for me and said if it comes on again come check it again and if its the same error code then its your coilpacks, and on my way home the engine light came on again.
so how long do you guys think i have until it start to mis fire?
mine came on when i was driving home from work, it came up with the engine light, did an engine diagnostic cuz it sounded n drove like a rexi (no offence lol :D )...
replaced all coils with splitfires n been beaut eva since.. no point replacing the bad 1 cuz if 1ns screwing up its more than likely they will all start going...
strange it aint miss firing already tho :laugh:
<br />yeah the car is not shaking or miss firing.... its pretty weird<br />i wanna make sure before spending 700$ to change them <img src="http://www.skylinesaustralia.com/forums/style_emoticons/default/sad.gif" style="vertical-align:middle" emoid=":3some:" border="0" alt="sad.gif" /><br />
<br /><br /><br />
its a real nuisance about o.e.m R34 coils but there is no option except pull your coils out and find the duds - my experience was Code 21 randomly appearing first with absolutely no noticeable effect but within less than a 1000k big trouble - it was suddenly so bad it was virtually undriveable luckily I was only about 3 k from home so ran it back anyway on about 4 cylinders as it was early Sunday and no traffic about - not a nice experience - hardly made it back - put in new coils and instant new car feeling!
this is what you need to do.
Take the kick panel off, take the ecu out of the car (undo the 10mm bolt) unplug ecu from harness.
Then plug the ECU back in, when you put it in just tightening up the 10ml bolt is NOT good enough, give the bolt 2 turns then push the plug in on EACH side then repeat this untill the bolt is tight.
Make sure the ECU is pluged in ALL the way and there is no gap. I have seen this happen on countless nissans where people DON"T put the ecu back in properly and they get error codes and engine lights because a sensor does not have a good enough connection.
Try this and let me know how it goes before spending big $$$ on coil packs. Even if it looks like its connected properly, still take it out and put it back in the same i explained.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
