hello there,
rb26 garrett -5's, with all the other bits and pieces
would anyone like to help me out with advice on when it is a good time to change the ol' cams,
i have about 320AWKW at 18lbs, going to wind boost to about 20lbs for a bit, and was thinking the next step would be cams? if so what is the pick of the bunch for low down power/torque? i see poncams seem to be one of the fav choices,
what roughly AWKW does it make sense to upgade?
thanks for any help
https://www.sau.com.au/forums/topic/252008-rb26-question/
Dont think you need them at that power level. Cars with 400AWKW seem to have them done.
yeah have read on this forum about not needing to touch them to around that power, but some others say they are a great updrade for low down power?
https://www.sau.com.au/forums/topic/252008-rb26-question/#findComment-4360538
For that power and stock rev limit cams are a waste of $$ and will do nothing for low down power.
Cam gears on stockers works well though...ive had great results with them.
https://www.sau.com.au/forums/topic/252008-rb26-question/#findComment-4360558
The cam gears alone are great value. Even on stock turbos.
I understand the standard cams have a following with some reputable tuners. There are also a number of people who have upgraded and found better power delivery.
Whether it's the -5's or even stock turbos, taking the tuner as your guide is the best bet. If they are sure of the stock cam optimum setup then go with that and you get the best value.
Personally, on the unported head standard motor, I would take the pepsi challenge any day to get more power everywhere over well adjusted stock cams with a set of tomei poncams. However it took quite a bit of fiddling on the dyno last time to get the best out of them (mates rates dyno though).
I'll be giving the tomei cam upgrade a go again shortly and this time I will get the settings down for others to draw from.
https://www.sau.com.au/forums/topic/252008-rb26-question/#findComment-4360623
hmmm, was going to get the boost turned up to 20lbs and see how that feels (on standard internal motor, rev limit 7500, have a profect b so will also run 15lbs) am a lil bored on 320 AWKW, dont know how much power 20lbs will produce, but im sure more then enough for me, then when motor gets tired go forged rebuild but maybe just leave the cams?
ps. sorry dont know what cams are dialled too
Edited by donkey
https://www.sau.com.au/forums/topic/252008-rb26-question/#findComment-4360641
I have actually witnessed in person on two cars that have removed poncams ONLY and lost only a couple of top-end KW but gained everywhere else in the rev range by refitting and dialing in stockers. Both cars had two different low mount turbo combinations...but to help your point i dont believe that the poncams were dialed into optimum position (well lets just say they werent set where i would run them).
https://www.sau.com.au/forums/topic/252008-rb26-question/#findComment-4360650
i think i will just stick with the standard cams, really dont want to through away thousands of dollars for not much gain, im looking for torque not massive KW's
again...where are the vernier gears set to at the moment?
https://www.sau.com.au/forums/topic/252008-rb26-question/#findComment-4360694
Yeah I've heard of a few more as well that have talked about poncams not getting the width of power like that.
I wonder if it is to do with the setting of the cams as you mention or if there is also some overcamming / profile mismatch going on if these examples are ones being ported /rebuilt motors . I think regardless that the off the shelf limitations we have with the RB's puts all engine setups at some sort of compromise. We don't have access to the variety of profiles or custom grind's other motors have. It is possible that the off the shelf Tomei's are optimised for stock head dynamics.
I've done the stocker dial in also and I'm a big fan of it as a great budget mod, you pick up power everywhere and the settings are pretty well established for the average motor.
The experience I had with the Tomei units however, made me a convert. I gained more power from as low as 3,000 rpm up. From 3,000rpm onwards I had a better power band than the best stock cam cam gear adjusted car dyno I've seen and by alot down low. My brother who is a big block hemi fan , I let drive the car before and after, was shocked by the pull the car had from the cams final setup, such that he commented he may have to buy a GTR. :down:
https://www.sau.com.au/forums/topic/252008-rb26-question/#findComment-4360697
how far did you retard the exhaust cam?
https://www.sau.com.au/forums/topic/252008-rb26-question/#findComment-4360705
thats a co-incidence
Ah you have tried this setting too?
I'm not 100% that's the setting I wound up with but, it was written down on a bit of paper that I was using for notes on the car at the dyno.
The cams were R34 units in an R32 as well, with my rather dodgy looking standard R32 CAS modification :P
https://www.sau.com.au/forums/topic/252008-rb26-question/#findComment-4363296
Yeah i found that stockers worked the best there with overall gains...yes everywhere!
https://www.sau.com.au/forums/topic/252008-rb26-question/#findComment-4363306
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
