hey guys
i have a rb26 in my s15 its been recently rebuilt, i was driving it for a week or 2 and it now sounds like a wrx
i was running bcpr6es gaped to .8 i took them out cleaned them put them back in and it was fine then took it for a drive and it started to do it again so i bought new plugs the bcpr7es gaped to .8 and its still doing it i done a compression test and its roughly 140 in all what could it be? exhuast leak? head gasket? i have no idea
cheers
https://www.sau.com.au/forums/topic/252067-my-rb26-sounds-like-a-wrx/
to diagnose it if it is a coilpack problem, while the car is running like a wrx... unplug each coilpack one at a time... if it gets worse, when its unplugged that coil pack is fine.. if it makes no difference if the coilpack is plugging in or unplugged, try swapping that coilpack with another one from another cylinder...
if the problem moves with the coilpack, u can bet its faulty.
i changed plugs to and played with the coil packs to.... it would run as normal when cold....
till the coil pack would warm up then it would play up again :P would take a few mins as well befor it would do it, then it would start again.....
if you have the coin go and buy some spitfires
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
