  • Replies 273
Hello Darlings!!
I have much to tell, but right now i'm in need of sleep... so i will jump on tomorrow night and spill the beans. I'll be starting a new thread, as there are lots of points i need to cover. I ask that the mods keep watch as i do not want any negative / unnecessary comments.
Goodnight xo Nene
PS... Monster trucks and demolition derby was awesome!!!!
Hello Darlings!!
Goodnight xo Nene
I bet the monster trucks were awesome :(
Meeting with SAPOL reps went well yesterday. For those seeking immunity for illegal mods, you'll be disappointed. For those members seeking a fairer defect system and less "guess work" from the police, you'll be happy.
This meeting has taken a step in the right direction, an understanding on both sides has been established, and I'll leave it to Nene to put the details together.
:D
:D
thats fantastic!!!
well done Nene and everyone involved. well done
thats fantastic!!!
A fresh thread will be posted prob tomorrow. We will explain all bases covered at the meeting then.
:D
creating new thread now... apologies for the novel about to be posted.. (gimme half hour to finish)
And I'd recommend members read the details posted before they shoot their mouths off.
Sled will be watching :D
id like to see all constructive critism in the new thread, but at the end of the day there's freedom of speach and if people dont agree with whats said they should be able to post that without gettin the ban stick (all within reason)
Rhys im not arguing that!!! all i am saying, is that i aswell as roo and ben have put a SHIT LOAD of work into this... and where as EVERY opinion is welcome, it can be given in a mature manner. Not by just getting Nickers in a twist and going off like a chook with no head.
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
