Hey guys.
wrecking this 180sx. Located in Brisbane. parts and prices will be listed. if its not on the list just pm me.
thanks
Turbo Kit: includes Garrett 2540, thickwalled custom manifold(will never crack), External Gate, Screamer pipe, braided lines, Dump front pipe, hotpipe(if swapped with original hot pipe. $1900ono
Genuine Volk Te37's Silver with chrome lip. just been resprayed good tread. $2000 ono 5 stud off my other car. 9" front 9.5" rear! good offset
Ecu: Microtec lx8 - $450 inc loom
Microtec hand controller - SOLD
JIC fully adjustable coilovers - $800
Front mount kit- $250
Adj castor rods - $130
Crome 18in rims(as pictured) - $400
Diff - $150
Clutch Master - $80
Clutch Slave -$25
Reo bar - $130
Engine cross member - $140ono
Catback Exhaust $150
Pedal box - SOLD
Brake master and booster $80ono
Complied 180sx shell with windows $1200
headlights - SOLD
Rear fiberglass bar - $50
Front fiberglass bar - SOLD
brakes and rotors - $180
sway bar - $40
seats - $50 ea
Carpet - $40
Roof lining - $35
Dash(has crack) - $70
sr20 gearbox with ca18 cross member (2nd gear syncro gone, still works though) - $100
550cc Injectors - $450
walbro fuel pump - $80
fuel tank(good nick) $150ono
lots more parts inc interior
thanks guys
ph: 0423 849 355
Edited by sly32
https://www.sau.com.au/forums/topic/253028-wrecking-180sx/
  • 6 months later...
  • 3 weeks later...
  • 8 months later...
