i've got a reclinable ergo at the moment but want to go fixed back bucket for some track work, question is, for daily driving when you must wear standard seat belt; does the seatbelt fit tight on your body whilst in the fixed back? or does it sit slightly off your body due to the "deepness" of the seat?????
also, will the standard seat belt wear away the seats material due to the design of the seat and friction??
https://www.sau.com.au/forums/topic/253053-fixed-back-bucket-seats/
I have a full bucket seat and use, when not on track, a normal seat belt and it seems fine, but its not exactly my daily car... I would suggest getting a seat belt pad thingy for the lower belt so it doesn't rub against the seat and cause premature wear...
never been hassled by cops either...
I've got a set of sparco sprints in my 32 at the moment. They're really comfy but getting in and out is a bit of fun. At the moment the part of the seat belt that goes over the lap has to go over the side of the seats and allow me to slip forward in the seat. I'm looking at threading the belt through the holes for the harness as shown in the following ms paint drawing.
Edited by Eddyfier
I have a sparco pro 2000, I don't find threading the belt through the holes like above is really worth the hassle, the belt holes at the sides arn't exactly easy to get to once I'm in. I want to get a harness bar for above the back seat. That way I can use either belt and it doesn't make the rear seat unusable.
  • 1 month later...
hi would you be interested in selling your pair of sparco pro 2000 seats?
please reply
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
