hey guys,
so first off,
can i use a rb20det fpr on a rb25det engine, reason is, i just broke the air nipple off the rb25 one on a bit of intercooler piping while i was putting the plenum back on, so if i could use a rb20 one that would be good, i have 4 spares or something lol,
second,
ive put a rb25 gearbox into my car aswell (r32), ive made a speedo drive, hooked up the reverse sensors (hoping the right way, will soon find out), and then there is 1 more plug which i believe is the neutral sensor,
so should i bother extending the plug so it can reach the loom? what does the neutral sensor do? and if i was do hook it up the wrong way how would i know?
any info on that would be great,
Cheers JV
https://www.sau.com.au/forums/topic/253102-2-quick-questions/
i don't know about the FPR, just try it and see if it will fit. i think the engines would use around the same pressure.
the neutral sensor isn't needed. i wouldn't worry about it. i'm not sure on skylines, but i know that in some other cars its stops you starting the car in gear, and i've seen another car that when you put it in gear it stepped up the revs a little bit.
Edited by QWK32
o ok, well if any1 else has info that would be good to,
it looks like the fpr will fit, but i dont wanna screw around with fuel pressure if they are different,
Cheers JV
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
