someone help me find a new ride to replace..
..the colt
yes the colt 45 is teh shiznit but i need something more practical for packing my drums in and also for my dog and pups.
i am looking for something small, funny looking, and cheap.
my heart is set on a Suzuki Carry van, those tiny ones wih the double sliding doors those are my ideal choice, so small to i could but cool wheels on them, neons, dumped (im jk, really i am) but yeah
have to be in manual
also, some sort of smallish panal van, i'd also consider a ute also
but im more into the suzuki van than anything else, has to be rego'd
so everyone please, keep an eye out for me :P
willing to spend up to $2000, but would push just a little bit more
http://www.tradingpost.com.au/addisplay.as...arch&origpage=1
this is pretty much what im looking for
prefer reg, i'll probebly call this person to but yeah keep an eye out :P
You're looking to encounter an error?? hmm, should be able to pick one of them up fairly cheaply :P
You're looking for something pretty niche' there .. Suzuzi mightyboy?
why not just a cheap 4cyl wagon like a bluebird, corona or something? much more of them out there..
hahahaha thats no where near a big van, its pretty tiny, we have normal size vans here at work, these are no where near as big
hence why i want it, easy to park, and anything tiny is damn cool (in automobile sense, not teh peen)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
