Gday all
Just Bought an R33 gts-t Shell (Literally) the only thing it has is Front, Rear and Rear Quarter windows
I Have no Parts for it at the moment Buy them as i go. Where Should I Start?
Thanks
I will shortly be pulling a 235RWkW engine out of my R33 to make room for a RB30/26. Also available is a R33 GTST Powerfc and hand controller. Engine comes complete with GT3076 turbo. Splitfire coilpacks and Z32 AFM, if your interested??
https://www.sau.com.au/forums/topic/254713-where-to-start/#findComment-4396681
I reckon it will work out a lot more expensive and frustrating that just buying a working car..
If you're than keen on building it up, then try find a wrecked 33 that you can swap the interior and working bits from.
https://www.sau.com.au/forums/topic/254713-where-to-start/#findComment-4397376
yeah seems a little crazy.. unless you're thinking about a stripped interior drifter/track car or something. I'd say you'd really be struggling to find everything from forums/2nd hand, hope you know some one who works for nissan. might be worth buying a halfcut though as others have said.
https://www.sau.com.au/forums/topic/254713-where-to-start/#findComment-4397566
Halfcut gets you everything you need from dash forward. Schedule about 4k? (Haven't really looked into halfcut prices recently)
In terms of interior there is a guy in Perth wrecking 2 33's atm that will probably have most the parts you need. His thread is in the FS section (Car parts and Accessories)
Running gear you'd have to source, referring to hubs control arms etc and again that guy has a turbo 33 that hes parting out which should have most of what your looking for.
Once you have 90% of it in I'm sure you'll start looking for specific parts. If your doing the work yourself and its a bit of a project then good luck with it all and im sure it will be a rewarding process.
If you were looking at trying to get a cheap r33 this way you'd be better off selling this hell and getting a complete car.
My2c.
https://www.sau.com.au/forums/topic/254713-where-to-start/#findComment-4397602
Pretty sure he bought the leftover shell from the guy that was wrecking those 2 33's. It is smashed and literally bare except for glass: http://www.skylinesaustralia.com/forums/Bo...ts-t254005.html
To be honest man I think you would be better off buying a complete car. Not only do you need to fix the smashed up front end but you need to buy so many individual components to get it to a working state...it will be a massive headache.
If you were trying to do it this way to save money then I think you will be suprised at how much you dont save.
https://www.sau.com.au/forums/topic/254713-where-to-start/#findComment-4397638
Thanks Everyone For the input
I'm Gonna Keep The Shell And Do it up not to fussed bout how much it'll cost
I Just always wanted to build a car from scratch and what better car then an R33 Parts Aplenty
And as Someone mentioned above upon completion it will be very rewarding!
I've enquired bout a half cut from prestige motorsport is there anyone in W.A that imports Half-cuts?
Thanks All
https://www.sau.com.au/forums/topic/254713-where-to-start/#findComment-4399718
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
